It is currently Tue Jun 24, 2025 12:04 am
PostPosted: Fri Feb 24, 2006 12:30 pm
I've been searching for a source for the Hitachi TR6, but they seem to have disappeared. I read somewhere once that they were OK for routing binding/purfling channels because they have an adjustable angle base, and have an index point that attaches to the trimmer body, independent of the base. Anyone here have any experience with these, or know of a source?
Meanwhile, while searching for the TR6, I found this from Homier, who I've never heard of before.
http://www.homier.com/detail.asp?SessionKey=dO0mUAXA8xpwGpef eAIAAiD%2fBHWLlcGcVPVElE4BVnks90N0o2rBmehMavwWnFGadOJJRQ%2bF yx2B&dpt=9&cat=108&sku=02735
For $10 I thought, why not?, and ordered one.
CrowDuck
Chris Nielsen
Soquel, CA.
PostPosted: Fri Feb 24, 2006 12:34 pm
Chris, I have a TR6 and still use it quite a bit. Hitachi stopped making them a couple of years ago. There were some available on Amazon but I'm not sure if they have any left.
PostPosted: Fri Feb 24, 2006 12:41 pm
saw one of these the other day.. I was really impressed...
http://www.boschtools.com/tools/tools-detail.htm?
H=175980&G=66644&I=67466
PostPosted: Fri Feb 24, 2006 2:11 pm
No, Amazon doesn't have them anymore, nobody does.
That Bosch looks nice, but it's a fixed base without any side index. Oh well, guess I'll have to try to make something like John Mayes's rig on his binding video, that one looks pretty straightforward.
CrowDuck
Chris Nielsen
Soquel, CA.
PostPosted: Fri Feb 24, 2006 5:49 pm
Chris, I don't think you will be happy with that HDC laminate trimmer in the long run. I bought one and the plastic holder cracked the first time I tightened it. I made the mistake of buying too many inexpensive tools starting out and have now had the unpleasant fortune of spending even more money to replace them. Try not to get caught in the same trap of buying everything at once. You can't go wrong with one of the Porter Cable trimmers and can sometimes pickup factory refurbished (PC 7310) from CPO Porter Cable on ebay for around $70. I have 2 and can't tell any difference from the store bought one.
PostPosted: Fri Feb 24, 2006 11:31 pm
If you can afford it, buy a PC 310-the most universally praised laminate trimmer on the market. Usually about $US159 plus shipping.I have read just about all of the luthier related forum posts and archives out there and except for a break-in period for the collet to easily release a bit, I can't recall a legitimate complaint. Mine is set up for rosettes with a Jasper circle jig and then goes directly to my Williams/Fleischman binding jig-three 8-32 screws each change.Micrometer-like adjustment and so smooth.Then pick up Pat Warner's accessory clear base set (recently $35 incl. ship.)and go crazy making all sorts of jigs with them.
PostPosted: Sat Feb 25, 2006 1:32 am
Chris,
Homier is one of those outfits that travel around and sell at tool shows. They came through Memphis last year and I bought a couple of those $10 trimmers. The first time I used them, one of them burned up( as in smoke city) and the other one vibrated so bad it was virtually unusable. They did take them back though.
PostPosted: Sat Feb 25, 2006 4:36 am
I agree with Mike about the pc 310. I've used a lot of different trimmers
and that is certainly my favorite. You can find factory reconditioned ones
for around 130, although a new one is only 30-40 more.
PostPosted: Sat Feb 25, 2006 4:39 am
First name: Yukon
Last Name: Stubblebine
City: East Boston
State: MA
Zip/Postal Code: 02128
I've been loving my Rigid R2400. Inexpensive, rock solid, easy to setup, and
available at Home Depots everywhere. As I primarily do repair work I use it a
lot for cutting saddle slots which it does like a dream!
PostPosted: Sat Feb 25, 2006 4:48 am
[QUOTE=yukonarizona] I've been loving my Rigid R2400. Inexpensive, rock solid, easy to setup, and
lot for cutting saddle slots which it does like a dream![/QUOTE]
Yup...and a lifetime warranty! Also, no collet problems, comes with a fence and bearing guide,variable speed, soft start, and a hard case to store everything. Not bad for $100.00.
PostPosted: Sat Feb 25, 2006 5:07 am
I'd never seen that Ridgid before. It looks handy, and I like the variable
speed.
Unfortunately I just couldn't bring myself to buy one unless I could get a
Bishop Cochran base for it .
PostPosted: Sat Feb 25, 2006 5:50 am
I never hear anyone talk about Makita laminate trimmers. I have one and plan on getting another sometime in the future to leave set up on my binding jig full time.
I love this little trimmer, does everything I throw at it. It's great. And $120 canadian to boot.
Rod True38773.577337963
PostPosted: Sat Feb 25, 2006 6:44 am
I have one of those too rod.
PostPosted: Sat Feb 25, 2006 6:55 am
First name: Rich
Last Name: Barbera
City: Bay Area
I scored this one on ebay for $20.00. It looks just the Makita. It's a Superior SPT 189. The price was OK. I haven't put it into action just yet. It maxes out at 20,000 rpm's?
PostPosted: Sat Feb 25, 2006 7:20 am
I like the 310. It's a tiny router, really, all-metal, all-great. Doesn't come with fancy tilting bases or edge guides, though.
PostPosted: Sat Feb 25, 2006 7:53 am
I have 4 of the Makita 3707FC's I love em.
I have one of the cheap makita-esqe knock offs too. IT totally sucks.
PostPosted: Sat Feb 25, 2006 9:33 am
I have several of the Rigid brand tools, and have been happy wih all of them.
PostPosted: Sat Feb 25, 2006 2:17 pm
   Those $20 trimmers are not worth the cost. The runout is terrible. They will get you started but you may find they are not worth the trouble. I used to use them on my binders till I had a batch with bad quills.
   The best trimmer on the market for luthiers is the PC 7310. The base has a thumbscrew adjuster that is great for dialing in the perfect depth. I guess it comes down to you get what you pay for.
    It is very painful to ruin a $1000 set of BRW because you "saved money " on a cheap tool.
john hall
PostPosted: Sat Feb 25, 2006 2:23 pm
Points taken regarding those cheap trimmers. I do intend on getting
some good quality ones, but I have some other non luthier
applications that the junk ones will work for OK. I'm looking at one
of those Rigid R2400's right now.
CrowDuck
Chris Nielsen
Soquel, CA.
PostPosted: Sat Feb 25, 2006 5:37 pm
I bought myself a PC 7310 John, so in your experience it's the real deal for what we do ?
PostPosted: Sat Feb 25, 2006 7:09 pm
the Porter cable trimmers are very nice too.
PostPosted: Sun Feb 26, 2006 3:04 am
I love mine. I have makita and the PC7310. The base on the porter cable makes fine adjustments so much easier
john
PostPosted: Sun Feb 26, 2006 3:33 am
Amazon's selling the PC 7310for $93.09.
PostPosted: Sun Feb 26, 2006 5:04 am
They also are selling the 310 for $209.
PostPosted: Sun Feb 26, 2006 5:30 am
I have a Bosch and a PC 310. They both are very nice. I don't like the way the Bosch base adjusts up and down though. It never seems quite vertical to me. The PC 310 is a workhorse. It also looks like a droid from Star Wars. That's the real upside to it!
Users browsing this forum: Bing [Bot] and 6 guests
